Statically provisions uplink ports for all dynamically created VLANs.
| dynamic-vlan | Configuration options for dynamically created VLANs. |
| uplink-ports | Tagged uplink ports for VLANs created by system applications. |
| add | Add ports to dynamic VLAN uplink port list. |
| delete | Remove ports from dynamic VLAN uplink port list. |
| ports | Ports to be configured as uplink ports. |
| port_list | List of ports separated by a comma or -. |
| all | Clear the dynamic VLAN uplink port list. |
N/A.
Use this command to statically provision uplink ports for dynamically created VLANs.
# conf vlan dynamic-vlan uplink-ports add ports 16-18 # conf vlan dynamic-vlan uplink-ports add 20,22,24 # configure vlan dynamic-vlan uplink-ports delete ports 22 # configure vlan dynamic-vlan uplink-ports delete 16-18 # configure vlan dynamic-vlan uplink-ports delete all
This command was first available in ExtremeXOS 15.3.
